How much did front RA calipers set you back ? and the HEL braided lines? Were they made for a RA or NA LANCER ?
Thanks!
Will Brembo Evo X Brakes fit a normal Lancer ?
denzza wrote:How much did front RA calipers set you back ? and the HEL braided lines? Were they made for a RA or NA LANCER ? Thanks!
The RA calipers were 2nd hand. Cost me $350 from memory.
Braided lines were sourced from Pro-Speed Racing. You'll want RA ones. Here's the link.
http://www.prospeedracing.com.au/produc ... ines-total).html
If I remember correctly, Thorsten(element) and some of the Qld boys are planning to upgrade their RA calipers. If I were you I'll be calling dibs asap!
$350 for just the fronts ?
Yeah thanks alot Ryan! im gonna ask them now ahaa
So Front RA calipers with rotors and the HEL braided lines will be all plug and play into my lancer ?
And what are you using in the rear ?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
denzza wrote:$350 for just the fronts ? Yeah thanks alot Ryan! im gonna ask them now ahaa So Front RA calipers with rotors and the HEL braided lines will be all plug and play into my lancer ? And what are you using in the rear ?
Yep, $350 for just the fronts.
They're just simple plug & play =)
I'm still running my stock brakes on the rear.
