Help with underglow lighting - quick questions ASAP response
- rokpapaziz
I also run wires into the cabin from there ^^ but not everyone can access that one.
Right in behind the each of the strut towers there's grommets.
OR probably most suitable for you is in the front wheel arches where the front part of the side skirts end. There's a grommet there that you can push through and then in to the cabin under the plastic panels about where the boot and fuel door levers are on each side.
Hope that makes sense
each to their own
i bloody love underglows for their uniqueness
dont see them on cars and they look fat on cj's
its easy, ill take photos of mine if you need a little guide on where to mount and stuff like that
just make sure you ground really good and protect your soldering with heat shrink or electric tape
use an existing 12v from your car and that should have a fuse too
