Engine light on after playing in fuse box :/
bennieboi101
Postby bennieboi101 » Sat May 04, 2013 12:25 pm
Hey guys, so i was attempting to install some neon’s in my car (i know stereotypical) and i was looking in the fuse box to maybe wire into the parkers. I saw one of these big massive square fuses that i had no idea what it was (later found out its a relay not a fuse) and anyway, i took it out and put it back in no harm done right?
WELLLLLL now my engine light is on for some reason and won’t turn off. The car appears to be running normal (as far as my complete lack of car knowledge can tell)
I looked under the fuse box cover and it was the "E" location and has a picture of "A/T then picture of the engine light"
This is a 2011 ES Lancer :)
bennieboi101
Postby bennieboi101 » Sat May 04, 2013 1:40 pm
i did and i didnt even turn the car on when the fuse was out.
i checked some other threads about engine lights on and i removed the negative battery cable and then put it back on, problem fixed :D
Josh_Emerton
Postby Josh_Emerton » Sun May 05, 2013 5:52 pm
When I was a kid, we had sand boxes to play in :)
Tweak
Postby Tweak » Sun May 05, 2013 5:53 pm
are you sure the car was not on ACC when you pulled the fuse?
bennieboi101
Postby bennieboi101 » Thu May 09, 2013 6:14 pm
Josh_Emerton wrote:When I was a kid, we had sand boxes to play in :)
HAHAHA i know right
@Tewak i have no idea what i really pulled out but all i know is its all working now hahaha.
Return to “Electrical”
Users browsing this forum: Google [Bot] and 13 guests
