Rough idleing * update *
Postby SIX » Sun Mar 03, 2013 7:19 pm
hey guys
there other day i was in the CBD and all of a sudden the cars stalled , it is a manual but i had the clutch in , i restarted went to the next lights had it in neutral and idle started bouncing between 200 and 1k revs and its did it for the rest of the day, i started the next day and it was fine
any ideas
mark
denzza
Postby denzza » Sun Mar 03, 2013 7:43 pm
take it to Mitsubishi ASAP !!
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
Postby Metalstrix » Sun Mar 03, 2013 7:51 pm
Yeah Marl, take it to mitsu like denis said
Postby turbogirl » Sun Mar 03, 2013 7:59 pm
Get it to Mitsubishi ASAP. Hopefully just something simple relating to fuel, air or spark but they will put the computers on it.
Seffy
Postby Seffy » Sun Mar 03, 2013 8:00 pm
Yeah take it to Mitsu. This sounds way worse than my one-off rough idle lol.
Postby turbogirl » Sun Mar 03, 2013 8:05 pm
If you have a good service manager they should slot you in straight away. I had rough idling and noisy injectors the other day but thankfully turns out was just a bad batch of fuel, Mitsubishi slotted me in that morning when it's normally eg two week wait for service. Good luck!
Postby SIX » Sun Mar 03, 2013 8:06 pm
yeah i take it tomorrow , not sure if it was what elizabeth mitsubishi did as i have only just had the 120 k service done ,but it hasnt done it again so it might have a been a bit of bad fuel ???? lll take it to them and get them to look at it
SEB15
Postby SEB15 » Sun Mar 03, 2013 8:09 pm
Do you have any mods done? Check MAF sensor if is plugged in (unplug and plug back) Reset the ECU by disconnecting the battery! If that doesn't work take it to Mitsu, it could be: fuel pump or fuel pump relay or MAF sensor gone,
sounds like is struggling to mix up the fuel with air!
Good luck and keep us updated!
SEB15
Postby SEB15 » Sun Mar 03, 2013 8:14 pm
SIX420 wrote:yeah i take it tomorrow , not sure if it was what elizabeth mitsubishi did as i have only just had the 120 k service done ,but it hasnt done it again so it might have a been a bit of bad fuel ???? lll take it to them and get them to look at it
O2 sensor suppose to be replaced at 100.000km so it could be that too, the wholes on the sensor are covered with carbon residue and it send wrong info to ECU
Postby SIX » Sun Mar 03, 2013 8:20 pm
SEB15 wrote:[quote:3a47eb06e3=SIX420]yeah i take it tomorrow , not sure if it was what elizabeth mitsubishi did as i have only just had the 120 k service done ,but it hasnt done it again so it might have a been a bit of bad fuel ???? lll take it to them and get them to look at it[/quote:3a47eb06e3] O2 sensor suppose to be replaced at 100.000km so it could be that too, the wholes on the sensor are covered with carbon residue and it send wrong info to ECU
would that be covered by warranty??? or would i have to pay to get that fixed
Postby SIX » Sun Mar 03, 2013 8:24 pm
SEB15 wrote:Do you have any mods done? Check MAF sensor if is plugged in (unplug and plug back) Reset the ECU by disconnecting the battery! If that doesnt work take it to Mitsu, it could be: fuel pump or fuel pump relay or MAF sensor gone, sounds like is struggling to mix up the fuel with air! Good luck and keep us updated!
i havent done any work to the engine yet .... as i said its only did it for this one half day last tuesday , i hasn't done it again :/, and im a bad owner because i havent had a day off to take it back to mitsubishi
himynameisdaniel
Postby himynameisdaniel » Sun Mar 03, 2013 9:03 pm
Probably not under warranty, it would be the same as your air filter getting clogged.
Was this on a cold start or had the engine been running for hours.
remember that not everything gets logged.
If the fault can be easily re-produced it becomes easier for the techs to solve. as opposed to no fault found after waiting 2 hours.
I have had this when I was running the local brand of E10 without a tune.
The engine would knock for 5 seconds every now and then on a cold start. till the ECU decided to advance\retard the timing.
After that round of fuel i went back to 91RON and the problem faded away, presumably as the remaining E10 was diluted with 91 over time.
But yes as stated before, check the MAF and O2
Postby SIX » Sun Mar 03, 2013 9:56 pm
ok cheers guys
SEB15
Postby SEB15 » Mon Mar 04, 2013 5:18 am
SIX420 wrote: would that be covered by warranty??? or would i have to pay to get that fixed
If the car is over 120.000km i think is not covered anymore, the warranty is 5 years or 120000km!
Someone correct me if i'm wrong
Postby SIX » Mon Mar 04, 2013 8:04 am
Ok update.... Took it to Elizabeth Mitsubishi they believe it was just a one off as they tend to think it was a computer glitch as it has not done it again ... The idle is controlled by the computer system there for due to the service being done by them and not north east who I normally use they tend to believe that it's was the car adjusting (best way of putting it) to there service as both dealerships service the cars differently and use different products in the engine ( which surprises me a little )
With that mind the car has not been as sluggish as it has been when I got it serviced by north east it's has a bit more get up and go , so I'm going to see how it goes over the next couple of weeks and if it does it again ill take it in , if not then that's a bonus
Return to “ClubCJ Talk”
Users browsing this forum: Bing [Bot] and 16 guests
