Definitely without contention the more coats you apply the degree of difficulty of removal reduces substantially - it won't tear apart as easily and can be removed in a single attempt.
I recommend you don't skimp on application if you plan to remove it later, it will save you a HEAP of time!
Plasti dip questions
- Fizzlefuzzle
- Lancer Ralliart
Definitely the more layers the better! It also smoothed out the computer and texture with more layers added
<b> Proud owner of Australia's and club cj's first glitter pink 2011 CJ Mitsubishi Ralliart Lancer
</b>
