Problem with 1st to 2nd gear.... Manual
Thanks alot guys! You have helped me alot
Im going to take it to another place and see whats going on.
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
- darren1011
TrojanHorse wrote:Crunching could def be clutch cause it wont be disengaging properly. But yeah that popping out, I would say again, IMHO highly unlikely clutch. Can I take it to a gearbox specialist?
Get one to drve it and ask. To look at the box meanss dropping it out and opening it up which means at least a bearing and gasket kit. I'm not even certain they have a top plate. I'd have the linkages checked first, probably not by a dealer
So i should tell them to look at the linkages! and make sure they are okey?
Because i WD40 the cables yesterday, that are connected to the throw of the stick! and its was all good till today
so yeah its something with that!
- darren1011
I called up Mitsubishi again, and i asked them i think the linkages are loose or something. But he told me theres not to adjust lol and if they were to replace it, apparently its not under warranty :/
He kept telling me the clutch is worn out !!
Im going in 2 days to get a 2nd opinion
