Rear sway bar lateral locks issue...
denzza
Postby denzza » Wed Jan 30, 2013 12:58 pm
Installed the lateral locks yesterday, and getting some squicky noise from it when turning or going over bumps slowly:/
Any ideas?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
Postby sleeper » Wed Jan 30, 2013 1:05 pm
u lucky lucky bastard!
i`d kill for a good squick.
Dire
Postby Dire » Wed Jan 30, 2013 1:20 pm
Are they moving? Do them up tighter :P
Did you clean the grease off the bar before you put them on?
If they're not moving then maybe they're just rubbing against the bearings? Theres not many things it could be...
Edit: On this topic; does anyone have a link to where I can get some?
denzza
Postby denzza » Wed Jan 30, 2013 1:38 pm
You know what I mean mate.
If you not gonna help, don't bother commenting. Sick of smart ass comment on this forum.
Just need help with my car, not Dickie comments.
Dire, not sure man. Gonna either tighten it more or completely take it off.
Frosty
Postby Frosty » Wed Jan 30, 2013 2:46 pm
No need for that..
At a guess I would say the squeak is coming from the polyurethane bushings on the end links.
If they are brand new they can squeak quite loudly as they're settling in.
denzza
Postby denzza » Wed Jan 30, 2013 4:08 pm
Yeah thanks guys!
Found the problem..
The lateral lock spun around and was rubbing in the frame where the sway bar is connected to of the car.
Should do it up really tight then!
