Our keys can be a bit fiddly but thats worse than mine. Mine either comes out or it doesn't, I don't have to jiggle it. I'd be very careful how much force you use.
Honestly it could just be a 'you're doing it wrong' thing but if its not I'd be thinking about replacing it, especially if you've under warranty still.
Key sticking in ignition between Acc & Lock (to remove)
I have this exact issue Erin.
Mine turned out to be because I was using the spare key and hadn't been ground down over use.
Used my 'Spare Key' which turned out to be the previous owners main key and that worked fine!
