I have an 09 VRX with the R/F upgrade and i  havent been able to pull the unit out yet to have a look but does anyone have any photos of the rear of the unit.
Im looking for a USB port and an AUX port too, just to see what my options are.
im trying to figure out if i can mount an iphone dock in my console between the handbreak and gear stick that will both play music and recharge my phone. So in order to do this id run a split cable from the bottom of the plastic pocket that is already there which would run to the RCA in the front and also around the back of the unit hopefully to a USB port. it would be ideal if there was an AUX input at the back also, so instead of running the cable to the RCA input where its visible id keep it out of sight entirely
Any info regarding the R/F unit would be appreciated
	USB port or AUX in rear of OEM Rockford Fosgate unit
