transmission oil change
duane21
Postby duane21 » Tue Oct 02, 2012 9:48 pm
hi just want to know is it hard to do yourself and were do your check your oil level in a ralliart lancer ?
zedd82
Postby zedd82 » Tue Oct 02, 2012 9:59 pm
I haven't done a full change myself but it's not too hard. I would say if you can change your engine oil you should be able to change the SST fluid.
As they say, there is no way to know how much fluid is in the SST. You need to catch everything that comes out and measure it then replace it with the same amount again.
duane21
Postby duane21 » Tue Oct 02, 2012 10:16 pm
ok thank you just did a oil change on both my cjs and it was way easy but yea were do you tip the oil in or do you need to pump it in ?
by hand oil pump ?
duane21
Postby duane21 » Tue Oct 02, 2012 10:17 pm
on the transmission i mean
Glenn
Postby Glenn » Wed Oct 03, 2012 6:47 am
the fill point is underneath the battery tray. theres a black 8mm hex bolt under there. You'll want one fo the flexi funnels to avoid making a mess
underneath there should be 3 of the same bolts to drain.
duane21
Postby duane21 » Wed Oct 03, 2012 7:23 am
Great help thanks man :)
duane21
Postby duane21 » Wed Oct 03, 2012 8:49 am
Thank you but I just think my transmission oil is a bit old need new oil won't be to low coz I can't c any oil leaks or oil on the ground so just think its the filter and oil that needs a change
Glenn
Postby Glenn » Wed Oct 03, 2012 8:56 am
Simplest way is to get 2 10lt jugs and fill one up with the old oil then fill the other with new fluid till its about even.
should be looking at 6 and a bit for baisc drain or 7ltr if you also drain the oil cooler.
duane21
Postby duane21 » Wed Oct 03, 2012 9:01 am
I will do that change the full 7 litres might upgrade my oil cooler as well and ... Car has been acting a bit weird in the sence that it climes and drops in rpm when cold and the sst takes long and then short times to get into reverse
Return to “ClubCJ Talk”
