Short Shifter - TWM vs Torque Solution
Marek
Postby Marek » Mon Apr 30, 2012 11:23 am
Hi guys,
I'm very much interested in buying a short shifter soon and I was wondering what you guys would recommend out of the TWM Shifter or Torque Solution Shifter or other brand I'm not aware of.
I can get the Torque Solution for $130 with metal bushings or the TWM for $182 with metal bushings. Is the $50 worth going for the TWM?
*They both offer RHD variants.
Thanks! :D
Just checked shipping costs for both:
TWM was $55
TS was $17
_______
UPDATE
So I got the TS shifter delivered in about 7 days which was nice. The shifter and bushings came nicely packaged with no damage to them.
The whole process took about 90 minutes and I'm very happy with the final product. Each shift feels very solid and precise. Once they shifter gets worn in and I get used to the shorter distance, it will be perfect.
Installation was really not hard with the instructions available in their PDF. The hardest part was probably removing the cup at the end of the shifter. The rest was unscrewing, unclipping and replacing - and that was quite easy!
:D
LZY_EYE
Postby LZY_EYE » Mon Apr 30, 2012 11:26 am
The Torque Solutions does not mention a RHD model. Might be worth checking with them.
Marek
Postby Marek » Mon Apr 30, 2012 11:29 am
I emailed them last week and they said they do have them :)
Postby bd-850 » Mon Apr 30, 2012 11:32 am
I had the TWM shifter. 'twas a good shifter,
smooth shifts, not clunky
AdamD
Postby AdamD » Mon Apr 30, 2012 12:38 pm
I HAVE a TWM shifter. It's awesome!!!
Heard that the TS shift is shorter. 50% V 35%
AdamD
Postby AdamD » Mon Apr 30, 2012 12:40 pm
Nope, wrong. 32% (TS) v 30% (TWM).
Sorry, my bad...
Marek
Postby Marek » Mon Apr 30, 2012 12:41 pm
They say 32% for TS and 30% for TWM :)
Edit: Yep ^^
chris851
Postby chris851 » Mon Apr 30, 2012 2:40 pm
I have the TWM Shifter very happy, good instructions. good feel when driving in traffic and spirited. A weighted shift knob would help it too. I have stuck with stock till i find one i like the look of.
AdamD
Postby AdamD » Mon Apr 30, 2012 2:54 pm
I got the weighted piston knob thing from TWM, feels pretty good to shift with!
Marek
Postby Marek » Tue May 01, 2012 11:21 am
Since there was over $100 difference with shipping between TWM and TS, I decided to order the TS and give them a go!
I ended up paying $149 with bushings and postage.
I'll make sure to post my thoughts after it's installed :D
AdamD
Postby AdamD » Tue May 01, 2012 12:37 pm
Let us know on the quality of the package as well.
And yeah, TWM are a touch expensive. Cost me $350.00 all up...
craigeth
Postby craigeth » Tue May 01, 2012 10:12 pm
Can i be really ignorant and ask what makes a short shifter better than stock? Is it less drag on everything because it's not as tall? So smoother shifts?
www.twentythreeframes.com
Marek
Postby Marek » Tue May 01, 2012 10:16 pm
They basically just reduce the throw distance by 30%.
TWM has a good FAQ here:
http://www.twmperformance.com/faq/
Dirtee
Postby Dirtee » Tue May 01, 2012 10:17 pm
craigeth wrote:Can i be really ignorant and ask what makes a short shifter better than stock? Is it less drag on everything because its not as tall? So smoother shifts?
the distance between gears is alot shorter, so when you want to quick shift it is alot quicker and smoother because there is less travel
2010 Lancer Es - My Ride
Wanna be customiser!!
ACT Rep 2012
CJLancerInstalls - How-To's!
craigeth
Postby craigeth » Tue May 01, 2012 10:23 pm
That FAQ ES awesome. Thanks guys!
Return to “Interior”
