Hey,
Had my 09 ES 2.0L CVT for about a month and was checking the general things on it such as oil, other fluids and the air filter which was filthy! So went down to super cheap to get a new one. Just got the basic RYCO A1622 which is identical to the DENSO one I pulled out. Fitted the new one all fine and took it for a quick drive. Seemed all fine but when you put your foot down a little and the revs got to about 3000 its sound very noisy compared to before with the dirty one??
I have triple checked its in correctly and I'm 99% sure it is so I'm a bit puzzled as to why a new filter would make it so much louder??
Any help or advice would be great!
Cheers
Marty
2.0L CVT noisy after air filter change??
- ofey
- Alumni
It's probably because your air box isn't sealed properly after you installed the panel filter.
A good point Shane,
I found this one on ebay which I might go for....
http://www.ebay.com.au/itm/200728858756 ... 1403wt_932
