hi guys im installing a reversing camera just above the liscence plate next to the liscence plate bulbs. i know where the wires need to go but i cant figure out how to thread them through to the boot to hook up to the reverse lights.
Any help would be aprreciated
couldnt see this in similar topics and im pretty unknowledgeable about this kind of thing haha
Running wires for reverse camera
This may not be the best way, but it was certainly the easiest for me.
The spot you want is what I assume is a pre-defined point for the installation of reverse parking sensors.
I simply drilled a small hole from inside the boot and fed the cable through till I could reach it from underneath the car.
To make it easier with the drill: remove the spare tyre and wooden cover from the car. You should then be able to reach the circular point that you want to drill (which is directly beneath the boot locking latch hook).
Hope that helps you out in some way.
- Rob
- Rob
