thanks in advance
Hey! bonnet gapping
Hey! bonnet gapping
Hey i had bought a carbon fiber bonnet n had it installed, when i found out it was illegal i sold it, when i reinstalled my old bonnet the gap is uneven in certain parts, is there a trick to this is there special nuts for it that lines it up nice, cos i dont have the original nuts from the bonnet, any ideas?
thanks in advance
thanks in advance
- driftnut((
the nuts will cost you around 75 cents each from Mitsubishi. But before you pass on that enormous sum to MMA try undoing your existing ones. If there is a bit of play in your bonnet, try a slightly different position. Bit of trial and error should get it straight
Ride Of The Month June 2011
