TC- SST noise?? EVO X MR
- ClubspecCustomDesigns
- Club Sponsor
- Club Sponsor
Hi Sal had the car over to Ian they think they no what it is will let you no once it is fixed fingers crossed i hear you had a couple of issues with your car hope they sorted it !!!!!!!!!!
Hi All,
Well after a number of weeks the problem with my car is now fixed it was not in the TC-SST box ,Blue Ribbons first thought on what was making the noise was a drive pulley belt bearing but that was not right .But it was a bearing in the oil pump the boys at blue Ribbon Motors Ipswich were great they give me a lone car until they sorted it , can not thank them enough. As well Sal for pointing me in the right direction to get this fixed I knew that the noise was not right and to be told that it was just because the when these EVO's get a few ks on them that the box may get a bit noisy absolute rubbish any way they checked it all out before and after to insure that there was no damage to the motor I am thinking by that they check the oil was still being pumped OK !!through the motor it all came back good once again thanks Sal and I would recommend Blue ribbon to every one for their EVO's and Lancers and other Mitsubishi's. Cheers Gazza
Cheers Sal They were a great help, Awesome car you got going
there Sal . Gazza
there Sal . Gazza
scott_drake
I too had this whining problem some time back and it turned out to be a bad bearing on the idler pulley. Changed out the idler pulleys, tensioner and belt at one go and the car has stopped whining since
CBRD BBX Full/AMS IC/Injen Intake & UICP/DW 1000cc Injectors/DW 65C Fuel Pump/HKS Legalmax Catback/Ecutek Tuned/KW Clubsport/Cusco Rear Strut & F/R Sway Bars/Whiteline RCA/Rota Grids/Defi Fuel,Boost, Oil Temp/Pressre Gauges & AEM AFR/Blitz I-Colour BC & SST Temp Gauge/FQ 400 Bonnet, Rear Bumper & VG/Varis Side Skirt
