Just a question .Can fog lights be fitted to my SX ?
Probably cost a fortune
	Fog lights
i just received mine and there's not much DIY instructions out there and the instructions provided are useless :s
to answer ur question will it fit on an SX yes it does i got my set for 130 shipped off ebay. http://www.ebay.com.au/itm/390350070194 ... 1439.l2649
The ones off ebay are aftermarket, so Mitsu will probably not install.
The proper OEM fogs require a new indicator stalk which has foglight control integrated. The dealer also needs to reprogram the CANBUS to allow them to work.
The aftermarket ones probably come with a toggle switch which will need to be wired in.
LZY_EYE wrote:The ones off ebay are aftermarket, so Mitsu will probably not install. The proper OEM fogs require a new indicator stalk which has foglight control integrated. The dealer also needs to reprogram the CANBUS to allow them to work. The aftermarket ones probably come with a toggle switch which will need to be wired in.
Prefer the sound of OEM I'll look into price of buying and installing
My 2011 sx the best damn car Ive ever owned or driven !!!
 Waiting for mine to arrive
