Trolley Jack Locations?
Hi everyone,
Could you guys let me know where is the best place to trolley jack the car up at the rear?
Would it be the axle, as that seems like the most obvious thing to use. I'd like to use jack stands at the jack points on the rails near the wheels.
Just wanted to be safe rather than sorry.
Cheers,
Danny
Cheers,
Danny
- BrownSound
BrownSound wrote:I've been trying to figure out how to use jack stands with a standard jack.. So if anyone has any advice on this either please let me know![]()
(Sorry for high jacking the thread Danny - just thought it would be a good place to pose the question)
mmm maybe jack the car up and place the jack stand under the chassis rail.
My question to you is that if you need to ask this question maybe you shouldn't be jacking your car up and doing what ever work you plan to do.
- BrownSound
Chubb wrote:BrownSound wrote:I've been trying to figure out how to use jack stands with a standard jack.. So if anyone has any advice on this either please let me know![]()
See my worry was that the manual specifically states not to jack further up chassis rail. And you are probably right - I probably shouldn't, but if I don't I'll never learn right?
- soniclancer
After spending the night researching on using a trolley/floor jack on a front-wheel-drive car, I've come to the conclusion that there is no recommended location for using a trolley jack at the rear of the car.
I assume it's because that there isn't anything at the back that needs regular maintenance, unlike the oil and coolant flush at the front, so a hard point hasn't been incorporated. On a RWD or AWD car, the diff housing can be used as a jack point as it's one of the hard points.
I was originally thinking about using the suspension crossmember, but it looks like other car owners have managed to wreck their wheel balance and alignment by jacking from that location, so it's a NO NO. I've only ever had to jack the front up on any car, so this is new to me.
Here's a photo of the rear underbody (on SAM-24A's car):
There aren't any obvious hard points that I can tell.
It looks like the only proper way to get the rear wheels off is to use the scissor jack on the chassis rails, one at a time. Trolley jacks are not recommended for use on the rails, without an adapter, as there is a risk of bending the sheet metal.
Really can't see how this turned out to be such a drama requiring research just jack from the central rear cross member or from either side. You ARE NOT going to bend the car jacking it from the side.
Christ I have had mine airborne and I have not twisted the body the work, my car also tripods very badly on a regular basis often with the rear wheel 20 - 30cms in the air (my driveway is that step).
Chubb wrote:Really can't see how this turned out to be such a drama requiring research just jack from the central rear cross member or from either side. You ARE NOT going to bend the car jacking it from the side.
Well I wanted confirmation that the rear crossmember could be used as a jacking point for the floor jack. This is a matter of both safety and to prevent damage to the car.
Most of the things that I've come across refers to either using the rear differential housing or a specific manufacturer jack point, both things that FWD Lancers don't have at the rear. I asked the question in the first place as the car manual specifically says not to jack the car up anywhere else apart from the jack points on the rails.
Anyway, my question has been answered by Troy.
