Hey guys,
So here is the back story.
I did have HIDs but have put back the stock bulbs (did this a couple weeks ago).
Today I noticed the front right headlight (lowbeam) isnt working?
I checked the fuse box in the engine bay under fuse 17, it is fine.
Any ideas?
Thanks.
	Front left headlight low beam isnt working?
eeko wrote:Hi guy's, I have the exact same problem occur to me today... Opened up the fuse box and changed both left and right fuses as well as swapping bulbs and my left one is still out.
Any other ideas on whats happened?
Thanks
You probably dis not fit some thing properly.
Use a volt meter and check for power and trace it back.
