Hey all,
It's annoying when I noticed my car came with only the rear windows tinted from factory. Why not just tint the whole friggin thing!!
Anyways what do you guys do. Do you remove the rear tints and do everything again. Or just tint the front to match rear.
Also anyone know what's the darkest legal tint available is?
Cheers
Rear window tinted only on new cars.
- Latino_Ralliart
Like mattigins said, the glass itself has been darkened from factory (privacy glass) - it doesn't block out any uv/heat. What I did first was to match the fronts to the back, but during summer I noticed that it allowed a fair bit of heat through (and the puppies found it pretty uncomfortable)
The solution was to put a light tint (50%, but you can go lighter at 70% or even a clear tint) to stop the uv and block out some of the heat
we are fascinated by that which can destroy us...
billy boy wrote:Like mattigins said, the glass itself has been darkened from factory (privacy glass) - it doesn't block out any uv/heat. What I did first was to match the fronts to the back, but during summer I noticed that it allowed a fair bit of heat through (and the puppies found it pretty uncomfortable)
This is incorrect Bill. All the glass in all the lancers are UV protected including the windscreen.
I too was told by my dealer that I would need to fit a clear tint over the rear to protect against UV.
You just need to fit tint to the front 2 windows to match the rear for looks only.
I agree it looks silly with clear glass on the front and privacy on the rear.
- Latino_Ralliart
aspir3 wrote:This is incorrect Bill. All the glass in all the lancers are UV protected including the windscreen.
really? i was definitely told otherwise! well, you learn something new everyday. must admit, while it may block uv, it doesn't block any heat, i found a noticeable difference when putting a 50% tint over the privacy glass
Darkest "LEGAL" tint in NSW is 35% VLT (visible light transmission)
The Factory Privacy Glass is equivalent to 25-30% VLT.
So tinting your front door windows with 25% or 30% tint would make it "ILLEGAL" whilst 35% would make your front door windows appear lighter than the rears.
Whatever you do however, apply UV block-out clear film on the rears.
Sam.
Sam.
Sam .....
There seems to be a few differing opinions as to wheather or not the rear door windows and the rear screen is factory UV glass or not.
I have been told it is not, whereby others have knowledge that it is.
Therefore:
If it IS NOT Factory UV glass and you apply clear UV block-out = less heat inside you Lancer = "WIN"
If it IS factory UV glass and you apply clear UV block-out = even less heat inside your Lancer = "WIN WIN"
Sam
Therefore:
Sam
Sam .....
