Help?
jm
Help?
Postby jm » Thu Nov 04, 2010 8:44 pm
Hello everyone, been a while since I posted anything here so here goes....
I have the "carbon fibre" stick on decals for the door pillars. Problem is that even though they were put on properly they have now completely peeled off and left a lovely sticky goo in their place. I intend to stick them back on using Tarzan Grip or something equally sticky but i need something to get the goo that is currently on the car and decals off before I do it. Also some cleaning tips on how to prep the surface would be greatly appreciated.
Regards
Jas
Envoke
Postby Envoke » Thu Nov 04, 2010 8:46 pm
Go to bunnings or any other hardware store and look for something like "de-solv it" which are specific glue/residue desolvers which are car friendly (this brand being an orange extract) as for prep, clean and dry, so i suppose water and a bit of soap and then give it some time to properly dry.
Red goes faster. MUCH faster.
Postby aspir3 » Thu Nov 04, 2010 8:46 pm
Use prepsol to clean it.
I would use double sided take only to hold them on as one day you will need to remove them
FizyMo
Postby FizyMo » Thu Nov 04, 2010 8:48 pm
Ohh Prepsol mate
".FizyMo."
Chubb
Postby Chubb » Thu Nov 04, 2010 8:50 pm
Yeah mate prepsol or an orange based cleaner and as Troy said look for a high strength automotive double sided tape.
Mizta B
Postby Mizta B » Thu Nov 04, 2010 8:51 pm
Prepsol is the go, it removes wax and grease and sticky residue
Painters use it prior to applying undercoat or colour to ensure a good bond on a clean surface after preparation :D
Merlinised....
Postby ofey » Thu Nov 04, 2010 8:52 pm
Might I point out that if you have the receipt for that, you can go back to Mitsu to request a warranty replacement. That one will be 1 yr.
Even better if you bought it at point of sale. The warranty of the item stays with the car!!
jm
Postby jm » Thu Nov 04, 2010 9:12 pm
[quote="ofey"]Might I point out that if you have the receipt for that, you can go back to Mitsu to request a warranty replacement. That one will be 1 yr.
Even better if you bought it at point of sale. The warranty of the item stays with the car!![/quote]
Unfortunatley it's been nearly 2 years since I got them and I didn't buy at point of sale so no warranty for me :-(
Return to “Maintenance”
