Sportback Real Lights
Hey guys, quick question; how does one exactly get to the lights for Sportback? If case one burns? Or I want to modifty it sometime down the track? Cause It's all covered off. . . If anyone has any pictures, that would be great!
- bunnishiwa
There are 4 access panels all up. (2 either side) (2 on hatch & 1 each corner behind wheel well).
To access reverse/brake lights (attached to tailgate), there is a panel on either side remove it with a screw driver and you can access globes.
To access indicators/rear park lights (corner of car), lay across the boot and look up in the alcove between wheel well and rear end, there is a little cover you need to pop out to gain access to globes.
Reverse globes are T15, never checked other globe sizes
