Hi all,
Wondering where these 2 are (fuel filter and pump)? Heard they were both either inside the tank or beside the tank, but I can't seem to locate it? Tried looking in all the typical locations, but seems to not be there.
Any help is appreciated. Thanks guys!
-EXALTD-
Fuel filter and Fuel pump
- exaltd
Yes it is. I suspect it may be a bad batch of BP fuel that has clogged the filter up, which will not be covered by warranty and I will be charged for the cleaning/inspection, hence if I can do it myself using the helpful care of my TAFE teachers, it'll save me money.
I can't seem to diagnose it myself... care to chime in anyone?
Symptoms are: loss of power when going up hills (having to change gears more often than normal), and less fuel economy than normal - no difference in driving, done all I can to clean out everything and inspected spark plugs too. Only started happening these past 2-3 weeks or so. Been filling up only at BP stations with Ultimate 98.
ANy help is good help. Thanks all.
Mate that'll b cover by warranty, they have to. Well at least let Mitsi diagnose it, if they do do turn round and say no then at least they have found what is wrong and can b certain that it's not something other than the fuel filter
If u do filter u need the sealing rings as well as they will likely leak if not replaced
OHH YEA!!!!
