LED Lights
Post Things You Are Wanting To Buy Or Trade.
PYLee
LED Lights
Postby PYLee » Mon Aug 02, 2010 6:36 pm
WTB interior lights (dome + map) in white and number plate led light
pst cheers
PYLee
Postby PYLee » Mon Aug 02, 2010 7:07 pm
cool thanks champ
Lancer Evolution 10MR
Postby SAM-24A » Mon Aug 02, 2010 7:09 pm
I've tried a few different types and style of interior festoon globes in the past and found the SMD ( Surface Mount Diode ) type to be the best. They're the brightest, have a wider dispersion angle, last much longer, use less power and the least heat dispersion of all.
I purchased mine from Jaycar Electronics who source them from a electronics wholesale supplier called Electus. Single sided, 120 degree view angle. They're available in 3 sizes:
31mm ZD-0484 $12.95
36mm ZD-0486 $12.95
41mm ZD-0484 $14.95
They're also available from Bright Lights Auto Parts
[http://www.brightlightautoparts.com/LEDReplacementGlobes.html]
These however are double sided SMD's (twice as many diodes) 360 degree view angle, and different colors.
They're available in 4 sizes:
31mm 31F8 SMD 1P $7.50
36mm 36F8 SMD 1P $7.60
39mm 39F12 SMD 1P $9.00
43mm 43F12 SMD 1P $9.10
The single sided ones fron Jaycar are more suitable for map and roof light applications, since you only need to disperse light downward. And they disperse the typical blueish LED luminescence.
Hope this info helps you make a enlightening decision!
Regards: Sam
Chubb
Postby Chubb » Mon Aug 02, 2010 7:11 pm
Thanks Sam, mate how many LED do you suggest using for the map lights and the dome lights.
I think 12 SMD will be fine for the map lights but will they be bright enough to use in the dome light?
Chubb
Postby Chubb » Mon Aug 02, 2010 7:24 pm
Hoges wrote:Nathan,have a look in my garage
i have a pic of the lamps, the map ones i posted are fantastic.
Had the same in the dome but swapped it for a 12 smd which is a bit better but cause of the area its trying to illuminate, still a bit dull
Thanks mate so in the pic in the garage are they all 12 SMD? because it looks bright enough for my purposes.
Return to “Buying & Trading”
