Put your keys to your HEAD!
Postby DORA_ANNE » Fri Jul 09, 2010 9:14 am
Blakey wrote:haha signals cant hurt you unless they are like a radiation signal. like microwaves. but microwaves cant hurt you unless you pull the radiation unit out turn it on and aim it at yourself.,
that mesh screen on the door of the microwave stops the radiation from going throught the screen, and the metal case stops it every other direction.
not to mention you in your house with all your power running you are basically living in electromagnatism, that caueses cancer :)
not proven but some people says it does.
so im pretty stuffed if its true i work in High Voltage SubStations so im bathed in extreamly high electro magnatism everyday.
Blake yes unfortunate we are living among all this electromagnetism & radiation .... The scientists have proven the harm in this to a point where this can harm us .
At this stage 2 out of 3 people are getting some type of cancer ,I have done a lot of research & learning into the causers & cures of cancer " As I was nursing my Brother & my Father who had cancer "
Just a little bit of advice if I May ....I would recommend everyone trys to protect themselves From any sort of electromagnetism & radiation ,not only that it's the chemicals they are putting into even the containers we are using & when heated "in those dreaded microwaves " the chemicals leak into our food . sooo everyone please use glass containers
And the best way to help our bodies cope with all this is our Diet ...Heaps of green leafy vegs & fresh fruit as they say .
I Will get off my soap Box now :lol: As I could write a book on what I have learnt :shock:
Cheers Doreen :)
Dire
Postby Dire » Fri Jul 09, 2010 3:06 pm
You're right Blakey but microwaves (the object) aren't perfect and people living under high voltage power lines are shown to be less healthy (though maybe I believe the news too easily :P).
And yeah like I said idk if using your head for an antenna is dangerous, but even if it is its nothing compared to everything else we live through...
Users browsing this forum: Google [Bot] and 11 guests
