How to remove rear lip spoiler?
Jim G
Postby Jim G » Sun May 02, 2010 3:03 pm
After some searching it seems that most people recommend the heat+fishing line method but I couldn't find anything specific to the Lancer - are there any bolts or clips holding the lip spoiler on?
It's a stock 2008 VR lip spoiler.
25% off vehicle photoshoots for ClubCJ members!
http://codastudios.com.au
Alex.K
Postby Alex.K » Sun May 02, 2010 3:13 pm
apparently there are bolts holding the lip spoiler.
Sorry I don't know how they can be taken off.
Lancer -> Accord Euro -> M3
Postby aspir3 » Sun May 02, 2010 4:26 pm
I fitted my rear lip spoiler myself.
From memory there were 2 screws and double sided tape that hold it down. I removed the screw and held it on with the double sided tape and sikaflex.
If you remove the trim from the inside of the boot you should be able to see the screw. just check the hole way along as there mat be more then 2.
I would remove the screws and put longer one in and then tap with a hammer to help loosen.
If you go to your dealer they will be able to give you advice and show you the screws and probably the fitting instructions. It all helps.
tadz0rz
Postby tadz0rz » Sun May 02, 2010 4:29 pm
As far as im aware, there is no mounting or securing bolts that hold the spoiler on. It would be a bit overkill to have bolts and screws n all that jazz holding on a small piece of plastic when some double sided tape will do it just fine...
As others have said, fishing line and a hairdryer will do the job fine....
Btw, is your lip spoiler lightning blue? If so how much do you want for it :D
Shadows
Club Sponsor
Club Sponsor
Postby Shadows » Tue May 04, 2010 5:52 pm
In total there are 1 positioning stud in the middle above the rear brake light. plus 2 screw 1 at each side, about 1 ft away from the middle of the lip spoiler.
Image[flash width=600 height=200 loop=false]http://i438.photobucket.com/albums/qq110/X-Factordesign/E-MailBanner.swf[/flash]
86MIM
Postby 86MIM » Tue May 04, 2010 6:13 pm
If it's black and your willing to sell, let me know :) been looking around for quite some time :D
kii
tykkään kiiltävä, nopeasti ja se on saanut olla ähkyä.
_________________
ClubCJ Lifetime Member #86
tadz0rz
Postby tadz0rz » Tue May 04, 2010 6:36 pm
Nah ill be removing my spoiler and selling it. Im going for the sleeek look :D
Alex.K
Postby Alex.K » Tue May 04, 2010 6:42 pm
tadz the best way is to swap trunk lids just like you asked me to
You don't want holes O_o
tadz0rz
Postby tadz0rz » Tue May 04, 2010 6:51 pm
You see, theres only one member in melbourne with a blue lip spoiler...Ohh who is it who is it...OMG ITS ALEX. But you dont want to trade :P
Ill probley just get some vinyl and cover them up that way...
Alex.K
Postby Alex.K » Tue May 04, 2010 7:13 pm
sorry mate
i need a good rear view :)
Hmm i actually sighted a blue VR near my area.
you know what that means ;)
tadz0rz
Postby tadz0rz » Tue May 04, 2010 7:14 pm
Your about the same height as me, and it doesnt block my vision lol. Check it out at the next meet. Maybe i can persuade you xD
tadz0rz
Postby tadz0rz » Tue May 04, 2010 7:47 pm
yeee but im going for a sleeeeek look lol. I want to get some black tail lights before i do it aswell though
