Interior Neon/LED kinda done =]
Alex.K
Postby Alex.K » Wed Apr 28, 2010 8:03 pm
Adrian is here to save me!
That's what I suspected...
Hmmm looks like I gotta get a solder and some soldering iron.
Cheers Adrian
Lancer -> Accord Euro -> M3
SIR-VRX
Postby SIR-VRX » Wed Apr 28, 2010 8:20 pm
Super-Adrian to the rescue!!!
tadz0rz
Postby tadz0rz » Wed Apr 28, 2010 8:23 pm
Im sorry adrian but...
**Facepalm**
Alex.K
Postby Alex.K » Wed Apr 28, 2010 10:20 pm
*facepalm*
Still I need help :P hehe so
HELP Super Adrian!
Hope this would be my last question :)
This is my product
It has LED-Control Box with switch-two lines(+)(-)
So yeah I was wondering if I should attach another cable to (-) cable and connect that cable to door switched ground
So something like this
Control box with switch
|----------------------- (-) ground
|______ door switched ground
Thank you Super Adrian~!
SIR-VRX
Postby SIR-VRX » Wed Apr 28, 2010 11:21 pm
Follow this diagram:
You can see that the (-) from the neons (in your case the controls) to the 2-way switch. then from that switch it goes to a earth point on the car and one on the yellow wire.
That will allow you to turn on without the door being open if you wish.
Alex.K
Postby Alex.K » Thu Apr 29, 2010 12:02 am
Hmmm so in my case, i should have two cables from (-) coming out to connect one to permament ground and the other to door switched ground?
because my switch is on the control box
SIR-VRX
Postby SIR-VRX » Thu Apr 29, 2010 12:15 am
since you don't have a choice with the switch being the control box, you can either choose to have it wired as you do now, or with the doors. not an ideal kit you have.
if you want to hook to the doors, follow that diagram again but ignore the switch part and hook the (-) to the yellow wire.
Alex.K
Postby Alex.K » Thu Apr 29, 2010 12:29 am
Cool Thank you!
I might get a new kit when this LED kit EVER dies =]
Thanks heaps!
SIR-VRX
Postby SIR-VRX » Thu Apr 29, 2010 12:33 am
No worries. Why we are all here.
scraverX
Postby scraverX » Thu Apr 29, 2010 2:17 am
On the subject of LED's being bright... I gained a new LED as part of my stereo upgrade - it's the power light on the Sub control - and it's quite bright. Blue is probably the next most noticeable in terms of brightness (after white) with Green being slightly less bright again.
Car & Home audio nut.
Alex.K
Postby Alex.K » Thu Apr 29, 2010 1:51 pm
Thanks to Adrian
it is finally installed =]
Will post photos tonight ;)
Alex.K
Postby Alex.K » Fri Apr 30, 2010 1:08 am
Here is a photo.
It's not finished yet as I have to move the bars to a more suitable places.
And I'm going to add a switch so that I can turn them on even when the doors are closed =]
tadz0rz
Postby tadz0rz » Fri Apr 30, 2010 7:20 am
Looks the goods alex. Excellent work!!
Graham
Postby Graham » Fri Apr 30, 2010 7:58 am
Looking great :)
All that effort wiring it finally paid off :P
Daily Driver: Yamaha R1
Return to “Lighting”
