Removing Headlights
Removing Headlights
Is it easy to remove the headlight??
My bulb was blown and all the glass pieces are inside headlights.
I need to remove the headlight and vacuum inside.
Before I do that, I have to remove the headlight and move the clear cover.
I want to know how to remove it and it will be the same as installing angel eyes.
Thanks guys!!
Thanks guys!!
you gotta take out the bumper and bake the headlights to get it open.... this thread explains it....
http://clubcj.net/viewtopic.php?t=572&h ... angel+eyes
how did ure bulb blow up anyway man?
- ofey
- Alumni
Right, I looked at my headlight this morning and I thought. Why do you need to take out your headlights to get this done? Why not simply stick the vacuum cleaner hose straight into the hole?
You could just remove the headlight and either vacuum, get sticky roll or play-do in there to pick up the glass bits.
Or bake it like a chicken!! Roast headlights with abit of roast potatoes and anything else you like
.. But yeah if you do bake it, keep an eye on it as it only takes about 5-10mins to soften the seal and keep it away from the back of the oven
