ralliart rear rotors
- whitenight
just bought some new rear rotors from rda and had them slotted as well as far as i know they were for the ralliart but they dont fit the outside diameter is the same 302mm the thickness is the same 10mm the height of the hat is the same 60mm the only thing is differrent is the hand brake drum is different on the rda rotors to the oem rotor hand brake meassures 190mm on the inside, on the rda it meassures 170mm my question is , is there two different size rear rotor drums for the ralliart.
- whitenight
There is only 1 listing according to the DBA website.
http://dba.com.au/products/DBA4417SR
Also, according to DBA, they only do brakes for the ES/VR and the RA. So I would imagine there are differences between the VRX and RA rear, even if they are the same diameter overall.
EDIT: Don't mind me, they are all fronts on the DBA site
I should really read things and not do it half asleep
