Re: Rotor upgrade/replacement
Posted: Sun Apr 01, 2018 8:34 pm
For what it's worth I've got those rotors but with QFM HPX pads front and Remsa rear (supply issue with QFM for rear) so can't say about Bendix titanium.
The slots are about 2mm deep and 2mm wide so will take alot to grind away or bridge.
The constant cutting of the pads keeps them flat to the rotor so it wears down both evenly. I've had them in for 1 1/2 years and about 20,000 km and they are still flat, compared to the stock ones that had some fairly deep groves from trapped grit etc.
Only point of interest is sometimes there is a grinding noise and you can feel the slots modulating the brake pedal (supposedly normal and not an install issue).
