Penrite oil - MGO7580 - SST Transmission Fluid
the sam
Re: Penrite oil - MGO7580 - SST Transmission Fluid
Postby the sam » Mon May 23, 2016 1:30 pm
Never ever ever use anything but Diaqueen or Castrol transmaxx dual in the SST.
We have seen so many come in with clutch issues and other assorted problems, which once we pulled them down it was found they were running non genuine fluid.
If you have the money to throw around on new clutches and gearboxes then yes, feel free to chuck this rubbish in your gearbox. Otherwise, spend the money on the proper fluid.
You are welcome to come into our shop anytime and have a look at the gearboxes pulled apart on the benches and I can show you the comparison between OEM fluid and other "suitable" replacements.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
Craker
Postby Craker » Mon May 23, 2016 2:07 pm
the sam wrote:Never ever ever use anything by Diaqueen or Castrol transmaxx dual in the SST.
I think Sam meant to say don't use anything BUT diaqueen or castrol transmaxx dual in the sst.
2011 lancer ralliart sportback
192kw + 370nm at wheels virtual dyno by boostin juice tuning
Hyperflow intercooler, gfb respons bov , gs 3 port
ultimate racing uicp and licp, hyperflow cat back + hi flow cat
MCA blue coilovers and whiteline sway bars
T3 rotors and ds performance pads
enkei sc 22 wheels
Postby lancerdarryl » Mon May 23, 2016 4:26 pm
Considering the SST oil is something we don't change all that often I would think using Diaqueen SST oil is far better option than using something that may be detrimental to the transmission.If you throw a handful of coins into a money box every week you will save up enough $$ to buy the correct oil when you need it......
One other thing, looking at the Penrite website MGO7580 is manual transmission oil
Shaun Patterson
Postby Shaun Patterson » Mon May 23, 2016 7:14 pm
have heard alot of bad things about penrite
the ONLY fuids you should be using are diaqueen or castrol transmax dual
the sam
Postby the sam » Tue May 24, 2016 8:56 am
Whoops, my typo.
And you should be changing SST fluid every 20k km, not 45k km. The oil is the only thing keeping temps down in the box unless you have a heat exchanger sump, and when your temps get up there bad things happen in the clutch basket.
We see this way too often. Check our facebook page for photos of clutches destroyed from heat and others destroyed from Penrite fluid.
Return to “Maintenance”
