2010 CJ lancer SX hatchback manual...
With regards to a 6 month oil change as against the first service set up I thought no problems ie. out with the old in with the new, first ring my dealer find out what grade oil to get.
There are 9 dealerships in my area and no one came up with the same answer, it's hard to get past the girl on the switchboard and the service man who books you in, you dont get to speak to the actual work shop forman or the mechanic who does the oil change.
You get advised to read the manual when you study it there seems to be a very wide selection of oil grades one can select.
makes me wonder how it works, does the same grade get used in new cars sold in Darwin as opposed to ones sold in Tazzie with a vast difference in opperating temps.
This post is not meant to be a whinge just an observation, I have got myself sorted out I used a well known oil 10 W 40.
Alan
What grade oil in brand new Lancer?
- ofey
- Alumni
No 2 dealerships will use the same oils.
Most of them though will opt for a 10W40.
But they can't tell you either since they might change suppliers every 3-4 months.
- exaltd
I agree with Ofey.
No 2 dealerships use the same oil. It's whatever deal they can make with the oil supplier as to the cheapest oil they can supply that meets the specifications of Mitsubishi.
Just as a note, any dealership that uses Magnetec Professional (Castrol) are using 15w-40, as with Halvoline (Caltex). Just my observation from working in different dealership workshops.
For an all rounder, stick to 10w-40. But being in Perth, you can use with no hesitation and within specification 5w-30/5w-40 as well, just for a little less friction
