NA CJ Lancer Servicing Complete Thread
Quismiff
Re: NA CJ Lancer Servicing Complete Thread
Postby Quismiff » Thu Nov 30, 2017 8:49 am
The manic mechanic wrote:What type of manual transmission oil is specified for the 5speed boxes? Is it normal gear oil or something special?
Semi Synthetic Gear Oil 75W85 GL-4 from Peak Oils oscar look up.
2007 MY08 VR-X (cj-red)
The manic mechanic
Postby The manic mechanic » Thu Nov 30, 2017 5:25 pm
Cool, thanx mate!!
sarusa
Postby sarusa » Fri Dec 01, 2017 9:24 am
My car is a my15 ES Sport. first 5 services fixes at $260 each. Get mine done free as agreed when purchased new.
So far first 2 done at no cost, third one coming up.
Note you mention only sump plug washer, manual states sump plug replacement on every service! Crazy and do they do it?
Will mark mine and check with next service!
Quismiff
Postby Quismiff » Fri Dec 01, 2017 9:29 am
sarusa wrote:My car is a my15 ES Sport. first 5 services fixes at $260 each. Get mine done free as agreed when purchased new.
To try and mitigate damage from over torquing, and stretching the threads and causing damage or cross threading, not many home garage mechanics do it, I usually work to PFT spec which is tight then another 1/4 turn, same with spark plugs.
Return to “Maintenance”
