Gearchange from 5th gear problem
Miss Wendy
Postby Miss Wendy » Sun May 01, 2016 10:22 am
Hi all, I was wondering if anyone has had trouble with manual gearbox change from 5th gear back to 4th and 3rd. When travelling uphill in 5th, I cannot select 4th or 3rd gear. I have to either go back to 5th gear, which almost stalls due to lack of speed or have to try to force/crunch it into 2nd gear. Had it back to Kelly Mitsubishi at Cardiff NSW, but they are unable to fault it. They said they have adjusted a few things and changed gearbox oil, which has made no difference. This problem doesn't always occur,(usually when engine cold or when travelled in 5th gear for long periods ie out on open roads coming back into traffic), but I am worried another car is going rear end the lancer as it almost comes to a halt until I can get a gear.
ChrisRalliart09
Postby ChrisRalliart09 » Sun May 01, 2016 12:51 pm
Sounds like a real pain, I probably wouldn't take it back to Kelly Mitsubishi and get someone else to look at it. If they find something can take it back to Kelly and show them where they may have made a mistake and fix it at their expense. Do you have any mods? Depending on the age of your car most things should still be under warranty.
BC Racing Coilovers, 3in Turbo back Exhaust, Merlin Tune.
Once you go black, your endlessly cleaning that.
Postby lancerdarryl » Sun May 01, 2016 3:17 pm
Wendy, take it into Klosters ask for Tim at the service desk.
Miss Wendy
Postby Miss Wendy » Sun May 01, 2016 6:16 pm
Lancer is still under warranty. With regard to taking it to Klosters....I have had mixed feedback about their service..I suppose weighing it up..Kellys haven't been of much use anyhow. It hasn't had any mods done to the gearbox.
toc
Postby toc » Mon May 02, 2016 6:16 pm
Miss Wendy wrote:Lancer is still under warranty. With regard to taking it to Klosters....I have had mixed feedback about their service..I suppose weighing it up..Kellys havent been of much use anyhow. It hasnt had any mods done to the gearbox.
Give it a go - best that will happen is they find and fix problem during warranty.
Worst that will happen is they won't find the problem.
Miss Wendy
Re: Gearchange from 5th gear problem
Postby Miss Wendy » Sat Dec 17, 2016 1:34 pm
Well....this week a brand new gearbox arrived from Mitsubishi and was fitted under warranty. Kellys found metal shavings in the gearbox oil. When gearbox was dismantled they found that 3rd and 5th gear syncros were pitted. Car back on road and very happy...Thankyou to Kellys
darkage
Postby darkage » Sat Dec 17, 2016 3:06 pm
Good job. How many km's did your car do before the gearbox packed it in?
Miss Wendy
Postby Miss Wendy » Sat Dec 17, 2016 5:11 pm
127000 K's. On the last day of warranty. :D
Dannn
Postby Dannn » Sat Dec 17, 2016 6:25 pm
Miss Wendy wrote:127000 K's. On the last day of warranty. :D
Hahahahahaha the last day! that is awesome!
Merlinised
tonee
Postby tonee » Sat Jun 16, 2018 10:39 am
Hi mate I have trouble downshifting into 3rd, have you had a solution your gearbox problem?
Postby aspir3 » Sat Jun 16, 2018 2:52 pm
tonee wrote:Hi mate I have trouble downshifting into 3rd, have you had a solution your gearbox problem?
Not sure Wendy will reply as she hasn't logged on for 14 months.
Return to “Maintenance”
Users browsing this forum: No registered users and 39 guests
