Brake Fluid How Much do you need?????
gman90
Postby gman90 » Tue May 19, 2015 6:54 pm
Hi all could some one tell me how much Brake Fluid How Much do you need????? to change fluid do you need going with Penrite fluid Thanks Gary
himynameisdaniel
Postby himynameisdaniel » Tue May 19, 2015 7:33 pm
the whole system doesn't use very much.
if you do a good job you can get it to around 0.95 L
but i ended up going through around 1.2 L
so yeah get 1.5L to be safe.
Also mine is CVT.
I'm assuming you have done this before on other vehicles or have a power bleeder.
denzza
Postby denzza » Tue May 19, 2015 8:04 pm
Yeah i get 1L.
Do about 200-250mL each caliper :)
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
the sam
Postby the sam » Tue May 19, 2015 9:26 pm
Went through 700ml doing mine completely including about 50ml of waste.
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
gman90
Postby gman90 » Wed May 20, 2015 9:40 am
Hi thanksveveryone for the feed back I am getting my work shop the do the fluid change don't wont to stuff it up by doing it myself thx gary :o
gman90
Postby gman90 » Wed May 20, 2015 9:41 am
Return to “Maintenance”
