What used spark plugs look like....
Postby The X » Wed Aug 08, 2012 8:54 pm
Thought I'd share....
I replaced my spark plugs at 45,000km a couple of weeks ago...
I know it's not needed as the Iridiums have a service life of around 100,000k - but I got them at a 20% off sale ages ago at a cost of around $8 a pop, so no biggie.
The brown ring on the ceramic insulator is "normal" to an extent, tho i'm not sure it should be that much on 45,000kms :shock:
You can see the firing electrode tip end looks fairly clean, a small amount of deposit on it. The needle tip looked fine also the flat bit had some deposit but a groove indicating that any spark would have "contact" between the needle point and the metal conductor.
You can see some of the deposits falling off from the 2nd spark plug in the last two photos... :)
LZY_EYE
Postby LZY_EYE » Wed Aug 08, 2012 8:58 pm
Mine were almost identical when they came out too...
Postby Mitch » Wed Aug 08, 2012 9:06 pm
Does servicing swap them out on the 45000 service as my car as already had it but unsure if they actually changed them as the car is at 48550 now . Thankyou
LZY_EYE
Postby LZY_EYE » Wed Aug 08, 2012 9:08 pm
Nope, they stay in till about 80-90,000kms if following service book.
Postby The X » Wed Aug 08, 2012 9:09 pm
No Mitch, I think they do them at 90,000 as the spark plugs from factory are the same NGK Iridiums i replaced them with and they have a service life of 100,000k.
I guess closer to the 100,000k mark they carbon build up is more and inhibiting the quality of the spark.
Being they are such a low cost item, i swapped them out myself at 45,000. A nice clean quality spark can't hurt. :)
Postby Mitch » Wed Aug 08, 2012 9:11 pm
Ok Thankyou so much Pete. Have a good night :-)
cj_sx_2011
Postby cj_sx_2011 » Wed Aug 08, 2012 9:15 pm
it wont hurt warrenty if we done them at 45000 would it? i think 90 is way to long to change spark plugs.
Postby The X » Wed Aug 08, 2012 9:17 pm
As long as you use the correct spark plug with the same heat rating and gap distance, no warranty issues. Nothing wrong with going above and beyond the scheduled service requirements.
Postby DORA_ANNE » Wed Aug 08, 2012 9:27 pm
Pete Mitsubishi changed mine around my 90.000 service & they said that's about the normal K's they change them ....
cj_sx_2011
Postby cj_sx_2011 » Wed Aug 08, 2012 9:27 pm
thats what i was thinking aye. its not like spark plugs are dear. lol. but seriously 90tho is along time, whats the normal time of doing plugs in our car?
Postby The X » Wed Aug 08, 2012 9:41 pm
Normal time as we've said a few times is 90,000km. I don't know the "length of time" interval it has to be done, you'd have to check the book, perhaps at the 4yr mark they might tell to swap them out. dunno.
cj_sx_2011
Postby cj_sx_2011 » Wed Aug 08, 2012 10:36 pm
i didnt know i sweared soz pete, yeah i dont think ill wait that long to be honest.
squala
Postby squala » Wed Aug 08, 2012 11:57 pm
Ninety thousand kilometres is when Mitsu tells us to change the spark plugs, but the real question is when we should actually replace them. I want the spark to be uncompromised at all times.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
empror
Postby empror » Fri Aug 17, 2012 1:02 pm
Wish I had taken photos of mine when I changed them at 80,000..
Yours look clean and almost new compared to how mine came out...
Return to “Maintenance”
