Page 4 of 6
Posted: Wed Feb 01, 2012 5:51 pm
by shamrockshirts
Are people really 1000% sure that the castrol transmax dual or BOT 341 is exactly the same as the Diaqueen SSTF-1??? Are you sure that there are no special additives or friction modifiers in the Dia-queen that is not in the Castrol Bot341?
Is a very expensive mistake ($10,000+) and a gamble with your warranty if its not...
Not sure I would be taking this gamble with a 10 grand gear box for saving a few hundred dollars.
Posted: Thu Feb 02, 2012 1:30 pm
by zedd82
A couple of the guys on EvoM have been using the Bot 431 for a few changes so far and haven't had any problems with it in their transmissions.
Posted: Thu Feb 02, 2012 2:06 pm
by chris
Its the same animal Mitsubishi Italy use it when doing a sst transmission oil change.
Just a point yesterday when I inquired about the oil filter I also asked about the oil for these transmissions and they said they don`t supply the oil ?? but they can do the service for you, seems like ford have it tired up more than mitsubishi.
Posted: Mon Feb 06, 2012 8:39 pm
by chris
Wonder what colour it is Ken maybe red?
Posted: Tue Feb 07, 2012 8:35 am
by chris
What colour is sstf-1 ? heard a few different stories, I thought it was green.
Posted: Tue Feb 07, 2012 9:51 am
by SEB15
It my change the colour!
I did the basic service ( engine oil and oil filter)
and the geniune oil from Mitsu was dark green before i put in to the engine
After my be 100 km i checked the oil level, and the oil change the colour from dark green to brownish colour!
Pls note before to put geniune oil in to the motor i flush the engine with a cheap basic 15-50w oil to make sure the engine is clean ( been my first service since i got the car)
I know is a complete diffrent story, but the SST fluid my have same reaction like the engine oil at high temp by changing the colour!
Posted: Tue Feb 07, 2012 10:58 am
by chris
Yes I think you could be right about the colour change after being in service for a few thousand Kms, looking at the ford oil change it is quite possible it had that green look when it first went in.
Posted: Sat Mar 17, 2012 9:57 am
by bobcrusader
Just had mine changed at 45,000kms by Creat'd. It was black, but no visibile metal filings in the filter. Makes such a big difference to the shift - so smooth now and a little quicker.
Posted: Fri Apr 20, 2012 6:14 pm
by Zaffod.Beeblebrox
I was just quoted $1300 for a 45,000Km service and SST fluid & filter by Booths at Gosford, I'm waiting to hear from Kelly's at Cardiff. Is that the cost I should expect in NSW.
