Page 3 of 5
Re: Are K&N filters really worth it??
Posted: Fri Dec 25, 2020 12:09 pm
by bumblebee
Nothing wrong with the NGK Iridium
They will last for a damn long time
Remember plugs , filter , oil, fluid, tyres , brakes ,fuel, etc are all consumables item
Posted: Fri Dec 25, 2020 12:14 pm
by CJVR08
bumblebee wrote:Nothing wrong with the NGK Iridium
So NGK rather than DENSO? yeah I'm just thinking what I can service myself
Posted: Fri Dec 25, 2020 12:33 pm
by bumblebee
Either or
Whatever you can lay your hands on easier
My preferred choice is NGK
Posted: Fri Dec 25, 2020 1:53 pm
by CJVR08
bumblebee wrote:Either or
Do I need a special socket wrench for the plugs???
Posted: Fri Dec 25, 2020 2:20 pm
by bumblebee
Define "special" ?
I have a Crescent tool kit that has two different sized plug socket and one of these does the trick
The plug socket has from memory a small rubber grommet in the bottom of it
Other then that , nothing special about the socket
Posted: Fri Dec 25, 2020 2:23 pm
by CJVR08
I only have a small socket set with different sizes for normal bolts ? Do I need a specific size or tool to undo the spark plug?
Posted: Fri Dec 25, 2020 2:43 pm
by CJVR08
Do I need to buy a separate tool???
Posted: Fri Dec 25, 2020 3:53 pm
by CJVR08
What size is it like mm
Posted: Fri Dec 25, 2020 4:22 pm
by bumblebee
The spark plug socket I use is a 5/8 of an inch
They are a deep socket and have a rubber grommet in them that help protect the top of plug and help grip it so it doesn't fall out so you can insert it with out the plug dropping off and damage to the electrode happen
No doubt you can get them for under $10 at Autobarn or Supercheap auto
Did a quick check and this should do the trick
https://www.supercheapauto.com.au/p/too ... 21326.html
Posted: Fri Dec 25, 2020 7:32 pm
by CJVR08
Yea looks like I need a longer/extension to reach the spark plug, I got the cover off and the coil...
Do coils need to be replaced every so often?
Posted: Fri Dec 25, 2020 7:58 pm
by lancerdarryl
Only need to replace coils when they malfunction......I've replaced one on a customer car they are ultra reliable
Posted: Fri Dec 25, 2020 8:01 pm
by CJVR08
Well spark plugs I want to do because no idea when they were done last and thinking about iridium
Posted: Fri Dec 25, 2020 8:07 pm
by bumblebee
Have you replace the air cleaner as well or if it K&N given it a good clean also ?
Posted: Fri Dec 25, 2020 8:15 pm
by CJVR08
Not yet replaced air filter
Posted: Fri Dec 25, 2020 8:38 pm
by CJVR08
bumblebee wrote:Have you replace the air cleaner as well or if it K&N given it a good clean also ?
K&n is a bit dear?
Or will the K&n last a really long time?
What other brand should I get?
