Help needed!: ASC "Service Required" Error
Re: Help needed!: ASC "Service Required" Error
cheers mate, but mines still working. But there's a 2016 Lancer with 29k kms at the wreckers and the ABS module is $49 so I couldn't resist bagging it as a spare.
- Quismiff
dopey wrote:hey are all 2 litre Lancer ABS pumps all compatible? not that mine's stuffed but it sounds like the earlier models have issues and there is a 2015 Lancer at the wreckers with under 30,000 kms which I think would be good as a spare. thanks!
VIN numbers? I believe on the EVO and Ralliart are going to be different, RA may be the same but different pressures for the two pot fronts, the Lancers didn't really change much all had EBD and ABS so should be okay.
2007 MY08 VR-X
The pump is out of a bog standard 2l lancer ES so I'm hoping it will be compatible.
But now I have a spare chances are I'll never need to find out
dopey wrote:The pump is out of a bog standard 2l lancer ES so I'm hoping it will be compatible.
Just following up on this one dopey.. any need for the spare?
Does anyone know if newer pumps can be swapped into older Lancer - say 2015 to 2010 ?
Sooner or later they will fail again, the dude on eBay is the one to talk to
eBay item
184108708535
eBay item
184108708535
toc wrote:dopey wrote:The pump is out of a bog standard 2l lancer ES so I'm hoping it will be compatible.
sorry it's still siting in the garage as a good luck charm Only got it as I got to pull it out of the car and it only had like 30k kms
if I ever do need it ill be sure to update this thread
I had mine done by the guy on E-bay very happy I think about $350 or so beats the stealerships $2500 and with a 5year warranty.
I did a bit of a back ground check on these units turns out they are a product of that great German engineering, the company that makes them is a division of Continental Tyres.
kris42 wrote:I had mine done by the guy on E-bay very happy I think about $350 or so beats the stealerships $2500 and with a 5year warranty.
I'll add my name to the list now as well - 2008 VR-X.
Who was the ebay seller offering the service with 5 year warranty?
Thanks
Ecu fix in Melbourne
Go to eBay and type in "Cj Lancer abs pump" and it's top of the page
How close do the part numbers need to be
Mine is a 4670A265 - I can find 4670A539 for sale (and other numbers)
Will they all work, or does it need to be an exact match?
My assumption is that they are just revisions and "should" work, but we all know what assuming does.....
Thanks
Thanks
The part number is different for a reason. I wouldn’t go plugging one in just to find out. I don’t know what the difference is,it could be pressure settings for different size calipers or as you said different electronic versions. You may need to speak with Mitsubishi.
Just did some research the different part# do have different ECU versions.You would be taking a risk using the wrong version. If it damages the power supply inside the pump then you are back to square one.I would be wary of using a second hand matching numbers pump there’s a better than average chance that it may not have been repaired previously so it will fail in time.Repairing your pump and getting a five year warranty is the best alternative.
The power is supplied via the battery, the ECU attached to the back of the hydraulic module switches power from the battery to the pump directly.
I would be using the hydraulic and motor module, and switching back in your ECU unit, since the fault is probably the motor, and the motor isn't easily replaced without the hydraulic unit, but, the ECU might be able to be swapped over..
I would look to keep the original ECU, because it's probably got the VIN programmed into it and so swapping the ECU itself might open up VIN mismatch errors etc.
Disclaimer: I don't work for Mitsubishi or Ate (the manufacturer of the ABS module), I don't manufacture the devices, I have no internal knowledge of the exact components internal to each device.
The fault is C2116 low voltage.The problem is in the circuit board attached to the pump.There isn’t usually a problem with the pump or the motor
Team
Our car also now has this error.
Any tips on the Ebay sellers name.. I've been verbally quoted by my mechanic sending mine away 1000-2000...
