MUT3 - finally!
Local Victorian State News, Meets, Cruises, Information & Talk.
Beeble
MUT3 - finally!
Postby Beeble » Tue Jan 29, 2013 2:18 pm
Just so you guys know .... I finally bit the bullet and shelled out for a MUT3 diagnostic and reprogramming tool of my own.
So i no longer have to borrow one to do the things we do with a MUT3 :)
(and thanks very much to the people who lent one to me - you know who you are)
I got it to further my understanding of SST programming and behaviour, so i can do soem more experimenting on my own car when i want to, rather than relying on getting the gear from third parties all the time.
So if you're on CCJ and have any flavour of Lancer, and want diagnostic feedback or reprogramming done, I'll be happy to help you guys out.
I'm not saying I'll be able to fix it if a fault is found - but i may be able to tell you what it is and point you in the right direction!
http://BeebleTune.com
rokpapaziz
Postby rokpapaziz » Tue Jan 29, 2013 2:21 pm
This is cool!
Any chance you can investigate the Launch control rpm target with this?
Postby ofey » Tue Jan 29, 2013 2:23 pm
Adam, any chance we can figure out how to change the CVT's gear ratios?
Beeble
Postby Beeble » Tue Jan 29, 2013 2:32 pm
irving - yeah i'm looking into the CVT stuff. it looks tough, though. I might need you to crack some hex for me to really start sorting that out - but i did find (accidentally) a way to change the cruise ratio on CVT so the rest *might* be possible, one day.
Marcus - the LC rev limit has been bugging us for a while now. if myself or anyone else figures it out they will be Mr Popular in the SST world for sure!
right now we haven't nutted it out, but we are pretty sure it's hard coded into the SST firmware (rather than the ECU).
We can currently swap around firmware, but we can't "see" inside the various firmwares to play with them. The coding is very different to the ecu coding, and i must admit i'm not clever enough to crack it.
ijustatecurry
Postby ijustatecurry » Tue Jan 29, 2013 6:40 pm
*peace*
Beeble
Postby Beeble » Tue Jan 29, 2013 6:43 pm
also I've been doing some research on flashing Evo MRs with different SST firmware (from later models) with mixed but encouraging results. which WON'T void your warranty heheh
vermilioN
Postby vermilioN » Tue Jan 29, 2013 7:13 pm
I like the sound of that :P
merlin
Postby merlin » Tue Jan 29, 2013 8:39 pm
good job Adam.
what size is the SST rom?
I would be willing to at least poke around in there and try to work some maps out.
Beeble
Postby Beeble » Tue Jan 29, 2013 9:09 pm
1362kb from memory Dave
I'm happy to send you the files if you like. There's been a few guys try and unravel them but apparently the container is a tough nut to crack... quite unlike the ecu roms.
squala
Postby squala » Tue Jan 29, 2013 10:20 pm
ofey wrote:Adam, any chance we can figure out how to change the CVTs gear ratios?
Yeah, these are virtual ratios anyway, so they're only pre-programmed and in theory can be altered. The only problem I can see is how to get into the computer that controls the CVT and tap its algorithm, currently the same issue with the SST despite the availability of the MUT3.
It would be nice to have six short ratios for performance driving, then for a cruise, just leave it in D to get excellent economy.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
merlin
Postby merlin » Wed Jan 30, 2013 8:32 pm
1362kb????? geeze, I wonder if they filled it with rubbish just to make hacking tough.
And how come they suddenly need so much memory when they have been doing ok with less than 500kb I wonder.
fiveandahalf
Postby fiveandahalf » Thu Jan 31, 2013 12:42 pm
havent been on for a while and came across this thread! you've got my full attention..lol..i hope there is something for us poor cvt fellas. keep up the good work guys!
squala
Postby squala » Fri Feb 01, 2013 11:22 pm
merlin wrote:1362kb????? geeze, I wonder if they filled it with rubbish just to make hacking tough. And how come they suddenly need so much memory when they have been doing ok with less than 500kb I wonder.
Any idea what programming language they used for the TCU? :)
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Beeble
Postby Beeble » Mon Feb 11, 2013 3:08 pm
^^ not sure. no one seems to know!
Well Windows 8 was a fail
so the old dinosaur XP laptop is the MUT machine, and it all works well :)
Have tested it recoding VINs, flashing SST, running diagnostics and clearing codes - all good and ready to roll.
Postby himynameisdaniel » Mon Feb 11, 2013 3:28 pm
I think a good start would be if the transmission is actually manufactured by Mitsubishi or by another company (getrag \ ZF, etc )
Model and serial numbers printed\ etched on the transmission would help otherwise we will need to take apart the transmission and take photos of all the circuits PCB's.
If we find the manufacturer we might be able to get basic info on some of the tools that they use to program it.
As the MUT is only used to flash it.
Return to “Victoria”
