Fog Light replacement
Just got my lancer and wanted to change out the fog light bulbs for some PIAA Xtreme White plus bulbs. Just wondering if anyone knows how to do this and also whether they can be replaced without taking the plastic thing off the bottom of the car. Im horrible at taking off those clips... always end up breaking them
- nickbutterz
yea it really easy. idk there was a DIY somewhere idk if it was on this site. but uhm all you do is look at the fog light. and then that platic thing around the fog light there are 2 screws i think take those out. then there should be 1 screw on the fog light itself. take that off. then the foglight comes out. take the bulb out the back. put a new bulb in. reasemble. repeat on the other side
- Ozie
nickbutterz wrote:yea it really easy. idk there was a DIY somewhere idk if it was on this site. but uhm all you do is look at the fog light. and then that platic thing around the fog light there are 2 screws i think take those out. then there should be 1 screw on the fog light itself. take that off. then the foglight comes out. take the bulb out the back. put a new bulb in. reasemble. repeat on the other side
yep nick very easy! there are 2 screws, but you only undo 1 of them on each side, so be careful because the other screw is for the light adjustment...
- nickbutterz
Ozie wrote:nickbutterz wrote:yea it really easy. idk there was a DIY somewhere idk if it was on this site. but uhm all you do is look at the fog light. and then that platic thing around the fog light there are 2 screws i think take those out. then there should be 1 screw on the fog light itself. take that off. then the foglight comes out. take the bulb out the back. put a new bulb in. reasemble. repeat on the other side
im sorry =/ its been a while and i just said it from memory
- Ozie
nickbutterz wrote:Ozie wrote:nickbutterz wrote:yea it really easy. idk there was a DIY somewhere idk if it was on this site. but uhm all you do is look at the fog light. and then that platic thing around the fog light there are 2 screws i think take those out. then there should be 1 screw on the fog light itself. take that off. then the foglight comes out. take the bulb out the back. put a new bulb in. reasemble. repeat on the other side
no sweat buddy
