hey everyone just thought i would ask if anyone would like to purchase some leds for their cars cuz i m here in sg atm so gna get myself some and they r pretty cheap n gd quality..... this is the list of bulbs available..... http://www.DJenesis.com/led/DJenesis1.pdf
(sorry dint paste the link properly should be workin now)
Hope i aint breakin any rules here....... and if i do sorry....
ORDERS:
Ral1rt- 18 SMD 5050 Equivalent to: 54 LED H11 Foglamps (white) - $52.00
anyone for leds for interior and exterior?
um well gna get 5smd amber t10 for parkers 24smd white reverse bulbs and probs 8 smd dome light for the boot still thinkin bout whether i want to get a 3w festoon for the room light..... the gd thing bout this guy is he has every colour u can think of so thats awesome n his prices r one of the best i can find for these kinds of bulbs here n quality.....
oh yeah jace went 2 mcwell n ure right heaps of stuff but was so sad lol they have projector/angel eye kits for almost every jap car cept the cj even the ch had it n looked prdy sick..... the honda headlights looked awesome with real classy lookin audi style running leds and looked really close to what the audi has.....
yeah i guess i probs will get the room lights as well since they r cheap here n probs only comin back singapore in a years time n dont really wanna wait that long.... well bump if any1 wants some as well since there were a few ppl who missed the last grp buy..... cuz i will probs go and collect em sometime around the end of nxt wk or beginning of the following week just before i come back to aus....
jinxue
say if i was aiming for something like this but just the flashing white leds on the side of the door and the interior purple leds on the floow.. all the interior jobs.. how much LEDs, cost for them and how to install?
http://www.youtube.com/watch?v=hjXFfx48 ... re=related
JinX
depends where you buy and what brightness, Power LED's are expensive. they are 1W up to 50W LED they are high heat, high flux LED's that require a driver (transistors, Capasitors ect) they also have a Large light spread, of most of the time 120degrees(angle)
or you can get Through hole LED's they are usually cheap, if you buy from china or something you can get them for 0.05c each, depending on brightness. the more internal chips, make them more expensive. most are single chip LED's they can be bright to quite dull. they go up to i belie 5-8chips per LED, they are usually very bright. and use a high amount of current( like PowerLED's but not as bright and have a Small focus of light 40-60 degrees.
most threw hole LED's with a high degree spread are usually dull, except for the Side emitting LED's they are much the same as normal ones but emit light sideways and have a high spread 120-180
others are Piranna LED's (4pin 2pairs joined cath, anod ) mid current.
LED range from sizes of 0.5mm to >10mm
installation is quite easy just need a positive and negative, negative to a switch(or positive) then the negative(or positive) must have a resistor on or you will Burn it out, make it go black and bubbly. then from there to your LED, connect to a battery switch, switch then its lit. more then one LED connect a bunch of LED's in parallel each with there own resistor.
cost for LEDs is from 0.05c to $60 each, most are cheap besides power LED, usually start from about $2 going up to about $60 for a 40W power LED,
anything else you need help with i can help with most standard things with LED's im currently learning more complex circuits for LED's to make my own programmable LED circuits.
