VLAND Headlights
VLAND Headlights
Hello,
I am thinking of buying a pair of VLAND headlights from eBay with the sequential indicator.
I know they are quite popular lights so I've got some questions for those with them installed.
1. Do the DRLs function like real DRLs? i.e. they automatically turn on when the car is turned on and do not require you to constantly have your park lights on?
2. Do they have high and low beam. From the pictures it appears that there is only 1 bulb socket so is there a special bulb I would need? What bulbs do you recommend, I am after the cooler white rather than the warmer white if possible.
Thank you in advance,
Cade
Cade
Re: VLAND Headlights
Can’t help you with the DRL question but I would say the car would need to control what is happening with the lights.
As far as the globes go if it’s only got one socket then it would be an H4 globe. If it’s supposed to use a halogen globe then that is what you must use. LED or HID globes in halogen reflectors do not give you a very good light source. All you will achieve is dazzling oncoming drivers at night.
I believe the Vlands come with a wire that you plug into your fuse box for DRLs with constant power, until you turn your headlights on.chump wrote:1. Do the DRLs function like real DRLs? i.e. they automatically turn on when the car is turned on and do not require you to constantly have your park lights on?
No high beam function. You can fit a D2S HID kit with ballasts, or use H7 bulbs (LED if you want a cooler white output).chump wrote:2. Do they have high and low beam. From the pictures it appears that there is only 1 bulb socket so is there a special bulb I would need? What bulbs do you recommend, I am after the cooler white rather than the warmer white if possible.
MY09 Aspire - Sold
MY10 Ralliart - 183kw
Zephos are you saying the Vlands don’t have a hi/low beam function?If that is the case then they are illegal to use and will get you defected
Just had a look at the Vland webpage which isn’t helpful but they do show a single globe holder that will take an H7 or equivalent. H7 is a single filament globe so I don’t know how they get a hi/low beam. If it was me I wouldn’t touch them.
Could be wrong but I think the shutter inside the headlight adjusts to simulate a "high beam".
Pretty dodgy if that is the case.
MY09 Aspire - Sold
That makes sense. And yes it is pretty dodgyZephos wrote:Could be wrong but I think the shutter inside the headlight adjusts to simulate a "high beam".
- Lancer VR/GT
Just installed a pair of these on my car, been wanting them for a while now. As far as I can tell there is no high beam function and the DRLs are activated by switching on the parking lights. Kind of annoying but these lights look amazing
Tywhiteguy wrote:Just installed a pair of these on my car, been wanting them for a while now. As far as I can tell there is no high beam function and the DRLs are activated by switching on the parking lights. Kind of annoying but these lights look amazing
Thanks for that info,so obviously with only having low beam they won’t have any ADR approval in Aus.So fit them at your own risk.
- Lancer VR/GT
Quick update: had to replace my headlight bulbs because I got a faulty pair. Just went out to check and they do have a high beam, I’m guessing it’s a dual beam not 100% sure as I didn’t feel like staring into them but I was wrong when I said there was no high beam
Hey Tywhiteguy - can you tell me which bulbs you bought and what fuse you piggy backed onto for the DRLs? Thank you
- Lancer VR/GT
No fuse for the DRL, just turns on with parking lights. H7 LED Headlight Bulb, EASY EAGLE... https://www.amazon.com/dp/B0856Y79CH?re ... b_ap_share I believe these are the bulbs I used. It doesn’t state that they are dual beam but when I hit the high beams they do get much brighter. Just a heads up with the low beams on they are not very bright at night.
Hmm maybe we have a different style of light then. Mine came with a cable that has a double fuse on it for the DRLs. So it's gotta piggy back onto another fuse to work. Thanks anyway!
- Lancer VR/GT
I bought mine second hand so he could’ve possibly rewired them or maybe they make them different in different markets. What size fuse splitter does it have? All you do is find one the same size and that comes on with ignition and you’re all set
Tywhiteguy wrote:I bought mine second hand so he could’ve possibly rewired them or maybe they make them different in different markets. What size fuse splitter does it have? All you do is find one the same size and that comes on with ignition and you’re all set
Unfortunately it’s not that simple for Australia. They need to dim when the headlights are turned on and turn off or dim when the indicator is in use
