HID Headlights for 2010 VRX
Dyl619
Postby Dyl619 » Sat Dec 19, 2015 12:40 am
Was looking around for a new pair of HID headlights around 8000k as I have heard that is the legal colour temp limit. Just wanted to confirm my find and make sure it will fit on my VRX.
Ebay Find: http://www.ebay.com.au/itm/Xentec-Super ... pwxi1L9Qdw
If anyone has brought something similer the the same vehicle, i'd love to hear what you got!
Swerve
Postby Swerve » Sat Dec 19, 2015 1:50 am
Yes with the right globes that will fit. Keep in mind that aftermarket HID kits are illegal. Also you may need to get a headlight housing designed to withstand HIDs as they get hot. Unless you have a self-leveling system and washers its illegal. I have 8000K HIDs in my car at the moment I got a whole new housing as well thats designed for HIDs and I'm looking into getting dimmer globes and self levelling motors as at night I get flashed by a lot of people who think I'm high beaming.
Postby aspir3 » Sat Dec 19, 2015 7:46 am
No HID kits are legal for a vrx. They must be in projector headlights with automatic levellers and have washers to clean them.
HID are great lights but only when fitted in the correct lights. Unfortunately when they are fitted to reflector headlights they don't focus properly and spray the light all over the place, which gives the driver poor night vision and blinds oncoming drivers.
Police are getting very hot on this mod and if you are found to have caused an accident because of blinding another driver you could be found liable of the accident.
Swerve
Postby Swerve » Sat Dec 19, 2015 4:20 pm
Only legal if you have washers and self levellers. I said it was illegal as I didnt think the VRX had them and from his post im assuming he wants to use the stock headligbt housing. Doesn't need to be projectora though as some stock HID setups have reflective housing. As long as the housing is designed for HIDs.
zedd82
Postby zedd82 » Sat Dec 19, 2015 5:08 pm
You want see squat with 8000K, you should only go 5000-6000k at most, but even then like others have said they are illegal.
Postby SAM-24A » Sat Dec 19, 2015 5:51 pm
zedd82 stated
You want (won't :P ) see squat with 8000K, you should only go 5000-6000k at most, but even then like others have said they are illegal.
"EXACTLY CORRECT" .... :arrow:
I have an Aspire which come OEM with Projector 4200K D2S HID Globes.
I replaced them with Philips 6000K D2S HID Globes.
The result was just perfect for me .... Clearer & Crisper White Light on the Road without losing much forward / distance projection .... *thumb*
When selecting HID Color Temps, you need to realise that the higher the Temp Range (4000K to 8000K) the Bluer / Purple the Light & the Less Light Projection on the road .... :(
Whilst Blinding the Sight of the Oncoming Traffic ... *nono*
Damir
Postby Damir » Sat Dec 19, 2015 6:13 pm
but but OSRAM globes :(
Postby Metalstrix » Sat Dec 19, 2015 6:38 pm
6000k is best for brightness. As my master SAM-24A said, you can see more with white
Swerve
Postby Swerve » Sun Dec 20, 2015 4:09 am
Mine are 8000K and they're clear as day I only notice a very very slight blue tinge when i first turn the ligbts on for a few aeconds then its all white. And from the front of the car if i squat down and i am at a certain angle to the lights they appear blue. From the drivers seat its just a very bright white light. Ill take some photos when not raining
Shaun Patterson
Postby Shaun Patterson » Sun Dec 20, 2015 11:02 am
thye arent 8000k then 8000 is really on the blue side
6000k has a tinge of blue
Return to “Lighting”
