So, i recently put in aftermarket foggies into my lancer and wanted to adjust them to my preferred level, only problem is the passanger side isnt leveling. Ive done the drivers side without any problem, but no matter how much i turn the screw on the passenger side it doesnt seem to move
Any suggestions?
Unable to adjust the level of passenger side fog light beam
Most likely the gear that levels it is worn... unsure if that is replaceable as I haven't looked at them closely. Suggest you take it out and have a look inside it if you can see what issue is.
Users browsing this forum: No registered users and 45 guests
