Earthing kit... worth it?
Mr Charisma
Postby Mr Charisma » Sat May 23, 2009 7:13 pm
Make your own mate.
Aluminum rail
Short run of 4ga cable ( about a meter )
4-5meters of 8 ga cable splits into 5 runs
5 Bolts
10 8ga terminal connections
2 4ga terminal conections
My left over one was out of a car with a big stereo but you can never have too big a cables. When I finally get around to putting it in ill take some piccies and show you. :D
Love that car!
Postby ofey » Sat May 23, 2009 8:30 pm
You can actually get your own. Just go to Jaycar. Buy the thickest Oxygen Free Copper inslated cables you can afford and 8 pairs of lugs for a variety of points.
tmr_colt
Postby tmr_colt » Thu Sep 10, 2009 12:40 pm
If the engineers designing the electrical system thought that in factory form the car needed it, they would have put it in.
Like the other guys said, large current aftermarket stereo systems can benefit from it, but I wouldn't bother with a grounding kit and If I did I'd make my own for a fraction of the price that those aftermarket companies try to charge using large gauge wire & a distribution block of some sort.
Postby ofey » Thu Sep 10, 2009 12:42 pm
I don't know if I ever told you boys the price of the OEM Mitsu ones:
MZ606789EX - Earthing Cable Kit = A$188.00
And they'll allow you to ground 4 points only.
Blakey
Postby Blakey » Wed Sep 23, 2009 7:34 pm
better way to stop the dimming of stuff and give you car better eletricals install high farad capacitors. they will stop the voltage drops and dimming of lights and what not when using windows/ subs/ anything that will spike your electrical systems.
also why use 0Guage wire when are you possibly gonna run over 100Amps threw that cable? if so you will flatten your battery in like 1hour depending on the amphours of your battery. ie 100Amp hour is 100 can flow for 1 hour before its flat. or 1 amp for 100 hours. and so on depending on your battery i don't know what the CJ's have i haven't looked at it. but i doubt the in cars are i think sealed led acid battery s so they lose volts as they flatten so it will flatten alot faster.
why cant cars come with lithium battery's they are better they run full volts till they are dead.
someone should so buy the largest lithum batteries they can find and make a 12V system out of them.
cabin03
Postby cabin03 » Wed Oct 28, 2009 1:42 pm
Got mine from Motoquipe westfield Burwood for $29.95 comes with 5 4ga cable, gold plated connector and battery terminal, works well in my 15 yrs old car (in terms of throttle responds) but hardly feel it on a new car tho....
bryzabone
Postby bryzabone » Tue Sep 07, 2010 5:08 pm
ofey wrote:I don't know if I ever told you boys the price of the OEM Mitsu ones:
Refreshing an old thread here, but does anyone have access to the actual instructions for install on this OEM kit? I'm wanting to know WHERE exactly on the car the 4 points are, so i can build my own kit to OEM specs...
Mizta B
Postby Mizta B » Tue Sep 07, 2010 5:11 pm
Bryan
Have a talk to BSYDE (Paul)
He did his custom and it came up awesome with 0 guage cable (I think)
It works well he said for his big stereo etc :mrgreen:
Merlinised....
Postby ofey » Tue Sep 07, 2010 5:53 pm
Tell you what el cheapo me did. Go to Autobarn and buy this:
8 GA 6 EARTH GROUNDING CABLE KIT
Product Code: ARW6GK
This system is designed to enhance vehicle ignition due to improved relative voltage to the igniters and improved voltage delivery from the alternator.
Specifications:
- Enhance spark strength
- Reduce or eliminate ignition break up under load
- Increases torque
- Improves throttle response
- 6 earth cables provided (2 x 600mm, 1 x 780mm, 3 x 1040mm)
When you get it, cut it to size. Additional wiring adds resistance. Get the gold lugs from Jaycar and then refer to my document on this of all the grounding points I did... .
Won't so much help those with stereo systems but more so those who have alot of electronics around the place like MMCS
Blakey
Postby Blakey » Tue Sep 07, 2010 7:09 pm
Im buying a fair bit of 0Ga and 4Ga cable soon probably 20M of both, i can always sell what i dont use, if anyone wants any(i doubt im gonna use all 20M of both)
only its gonna be red cable
bryzabone
Postby bryzabone » Wed Sep 08, 2010 1:19 am
Good tip ofey, that looks the goods.
Question is, where exactly on the engine/bay/chassis do mistu. recommend for earthing points.
Diagrams/pictures of where ppl have mounted earth points would be awesome!
thanks guys
@ blakey-Thanks for the offer, i'll try to find 'dull' coloured cable if i can, to better match my grey engine bay. If i cant , i'll PM you! ;)
FizyMo
Postby FizyMo » Wed Sep 08, 2010 1:24 am
Any DIYs on this peeps? like what Bryan said, pics would be helpful
".FizyMo."
Blakey
Postby Blakey » Wed Sep 08, 2010 9:08 am
I even have heaps of copper bar, if people want to DIY it. (for what to connect all the cable up to.)
Postby ofey » Wed Sep 08, 2010 10:56 am
Alright it does seem that I never did a list of points to ground, so I'll do it here... .
Here's the view of the whole Engine bay:
Now working right to left as we view it:
4 points to note in this picture. From left to right as we view:
1. Original ground point
2. Fuse Box
3. ECU
4. Firewall
Now we route across with 5 cables.
1 point to note in this picture. You will see 3 blue cables going from right to left. See the distant end it's the
5. spark plug rail
One more travels below to the air intake:
6. Air Intake
The engine block itself under the cover sees 2 wires:
7.Fuel injector rail
8. Alternator (longer wire going across)
That's 4 down. The 5th one going from right to left is an original ground point you see:
9. Ground point on front left
So you need 9 cables in total and 9 extra lugs. I did it completely from the Aerpro kit. which provided me with 6 cables, I only had to cut 3 of those cables to get a further 3 more cables but needed 9 more lugs to make it work... .
bryzabone
Postby bryzabone » Wed Sep 08, 2010 1:20 pm
very cool! as always, you are the man ofey! too bad i cant +1 anymore!
(i'll rate 5 instead!)
Return to “Electrical”
