DVD Map based MMCS A01-A04 - The Definitive Guide for CCJ
TheCarn
Postby TheCarn » Sat May 31, 2014 1:22 pm
Picking the state (map if aus pops up) automatically sets your time zone
Yes it has Victoria selected but it hasn't set the time, nor can I make any changes apart from the time format. In the top of of the screen where the time is meant to be displayed it is just showing [--:--].
lantourismo
Postby lantourismo » Sat May 31, 2014 1:26 pm
You could check to see if everything is plugged in, however if your getting naviagation then the gps cable is fine. Is yours A04 or A01? It's printed on te front right corner
TheCarn
Postby TheCarn » Thu Jun 05, 2014 2:48 pm
Yeah i checked all the connections and all are plugged in fine. Its a A01.
Postby ofey » Thu Jun 05, 2014 3:05 pm
You might want to check if you're receiving any GPS Satellites.
If you don't have reception, you won't have any time displayed.
TheCarn
Postby TheCarn » Sat Jun 14, 2014 9:24 pm
Yeah my 1st post on page 9 says that I don't have satellite signal. My question was about fixing that, or even if it's possible to fix.
Postby ofey » Sun Jun 15, 2014 4:24 pm
did you install the MMCS antenna and mount it properly?
bongo
Postby bongo » Tue Sep 09, 2014 7:23 pm
Hi there. I need help. I just got my ralliart battery changed( 5years) but I had a copy map DVD. When I started car mmcs wanted me to insert map disc. I managed to swap the copy with original DVD (thanks forum) but now I have no clock. Disconnected battery and reconnected with original map DVD inserted but still can not get clock. Any one can help?
bongo
lantourismo
Postby lantourismo » Tue Sep 09, 2014 8:07 pm
No clock or your time is just wrong? Mmcs settings revert to default when the battery is disconnected
bongo
Postby bongo » Tue Sep 09, 2014 8:22 pm
No clock, just dashes
lantourismo
Postby lantourismo » Tue Sep 09, 2014 8:26 pm
With an original maps dvd
bongo
Postby bongo » Tue Sep 09, 2014 8:57 pm
Yes
bongo
Yes
lantourismo
Postby lantourismo » Tue Sep 09, 2014 9:01 pm
bongo wrote:Yes
That's weird.
Zaphod
Postby Zaphod » Wed Sep 10, 2014 7:58 am
Is the GPS tracking correctly?
Return to “Electrical”
