My boot light seems to have stopped working for some strange reason. Cables seems to be firmly connected, I also checked the bulb (12V 5W 28mm festoon) and it seems OK, doesn't look blown but its hard to tell.
Looks the same as this except it has 3 LEDS https://m.ebay.com.au/itm/1x-Car-White- ... 15IAAOSw4D
It lit up the whole boot which was nice but if it's a bulb issue then maybe I should avoid this certain type of LED in the future
Anyone experienced this problem before? Bulb has lasted around 5-6 months till now.
Boot interior light stopped working
- rasit.aslim
2017 Lancer ES CF Sport
Re: Boot interior light stopped working
Hey is the bulb the same as the inside dome light? Maybe swap them over to test it.
- rasit.aslim
Yes except dome bulb is 31mm and trunk 28mm, may have to buy a new bulb :p
Update: bought these, hoping they're good https://www.ebay.com.au/itm/123382975221?ul_noapp=true
that's only 3mm difference, as long as the tabs are touching the bulb it will be ok for testing even if it is a bit loose.
but it's most likely the bulb has gone bad. the ebay leds don't last as long as they claim unfortunately.
- rasit.aslim
True bro, thinking of buying a 1M led strip for $10 and just wiring it up. Will last longer surely haha
Yep, put a LED strip in my boot, much more light and I did the smart thing, got some joiners so if I want to I can put it back to stock easily.
LED strip light in the boot is a brilliant idea. I did mine a few years ago. I ran dual led string that is about one meter long. The amount of light it shoves out at night time is pretty incredible. Oh so worth doing
Users browsing this forum: No registered users and 39 guests
