CF key remote
rasit.aslim
CF key remote
Postby rasit.aslim » Thu Sep 21, 2017 5:00 am
Hi guys,
Is it possible to replace the 17' CF Lancer key remote with this flip type? https://m.aliexpress.com/s/item/3281918 ... 9#autostay
The current key has 3 buttons, lock unlock and boot open
Anyone converted their keys with one? If so how much did it set you back?
2017 Lancer ES CF Sport
Mooman
Re: CF key remote
Postby Mooman » Thu Sep 21, 2017 8:23 am
Looks like it is just a shell and you would have to destroy your current key to fit all the components inside.
I'd stay away from this as even in the photos given the build quality looks questionable, would suck to have a key break off in the barrel.
Re: CF key remote
Postby lancerdarryl » Thu Sep 21, 2017 9:22 am
They are rubbish,don't buy it.
ReeceCozaa
Re: CF key remote
Postby ReeceCozaa » Thu Sep 21, 2017 10:25 am
could try the GSR cf key, although it isn't a flip key it's a pull out one, since the higher trims are keyless start
We are all in it for the fun!
Quismiff
Re: CF key remote
Postby Quismiff » Thu Sep 21, 2017 10:53 am
Don't the mister minit key guys at most malls do this kind of thing? I know they tend to be a tad on the expensive side, but wouldn't you rather have the ability to take it back to him and jam it somewhere the sun don't shine should it ever fail?
http://www.misterminit.com.au/key_car.html
2007 MY08 VR-X (cj-red)
Re: CF key remote
Postby bumblebee » Thu Sep 21, 2017 12:18 pm
Have a chat to a local lock smith and see what you can find
Brace yourself for a price tag of at least $200
rasit.aslim
Re: CF key remote
Postby rasit.aslim » Thu Sep 21, 2017 4:07 pm
Thanks guys, I'll be going to mister minit and a few locksmiths to get some quotes
Moderator
Moderator
Re: CF key remote
Postby Mystique » Thu Sep 21, 2017 6:14 pm
A new key from Mitsubishi is around $400, so probably better to be safe than sorry and not do it.
2017LancerCF
Re: CF key remote
Postby 2017LancerCF » Mon Jan 01, 2018 1:35 pm
Not possible apparently from mister mint. Said the new keys have some sort of electrical ID and can’t be retrofitted to any key. Needs to come from Mitsubishi.
Re: CF key remote
Postby bumblebee » Mon Jan 01, 2018 4:35 pm
No need to buy the keys direct from mitsy.
You can if you all cashed up.
Im not so i bought one from korea for under $100 and got a locksmith to cut and program it.
Mr minit will say they cant make the boot button work.
From memory they used a MUT3 or similar tool to access the ECU and make the new keywork. It has a boot unlock function just the original.
However its not a flip style key. Just a standard OEM key.
Re: CF key remote
Postby Lancer1993 » Mon Jan 01, 2018 4:39 pm
I like the Lancer fob, most days I never see it. Stays tucked in my pocket and most times I don't even touch the fob, just use the door locks to lock the car. One of the best things I like about my VRX is the keyless entry and start.
burfadel
Re: CF key remote
Postby burfadel » Mon Jan 01, 2018 6:47 pm
I've never seen women working at Mister Minit...
Simple chip keys can be copied at a couple of hundred dollars. Ring around though, prices can vary greatly. Keyless keys are much harder even though without the key, keyless is left with just 'less'. Less is more, in this case the price!
Return to “Electrical”
