Australian service manual??
lantourismo
Postby lantourismo » Thu May 22, 2014 2:25 pm
Hi does anyone have a copy of the Australian service manual, I have looked at the one uploaded here, and because it's for the overseas model the circuit wiring diagrams are the same however the wiring colours and plug positions aren't the same.
Need to look at Australian circuit diagrams for wiring colours/position for etacs to headlamp relay, tail lights from etacs and wipers from etacs
lantourismo
Postby lantourismo » Fri May 23, 2014 1:26 am
Is there a way you could print screen me the relevant pages from the circuit diagrams section?
himynameisdaniel
Postby himynameisdaniel » Fri May 23, 2014 1:47 am
that's actually fairly easy to forge.
If you look around on the web there are whole technical communities out there that cater to this.
There are a lot of rootkit applications out there that cloak or emulate cdrom devices which allow you to have custom values on anything really.
It's how old school video game piracy from they last 20 years worked.
The most basic ones would read a file on setup and then perform a check from the target's registry value and check the serial number there.
MY10VR
Postby MY10VR » Fri Apr 22, 2016 7:43 pm
Delta Frag did you have any luck with this manual?
MY10VR-CT9A7RS2
Return to “Electrical”
