Side mirror motor replacement
Does anyone know if the side mirror motor from ASX/Outlanders mirror motors fit the CF side mirrors? looking at adding auto fold mirrors and was wondering if its easier to just replace the motor and do the wiring separate to the ETACS?
- adamhumphrey
Re: Side mirror motor replacement
Its not as easy as just changing the mirrors, you need to change the mirror switch on the door, the wiring in the car has to be there including the relays. Also the etacs has to be enabled to allow the power fold. Asx/outlander mirrors are different (well my 2020 ASX mirrors are different) to my 2010 Evo X
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
adamhumphrey wrote:Its not as easy as just changing the mirrors, you need to change the mirror switch on the door, the wiring in the car has to be there including the relays. Also the etacs has to be enabled to allow the power fold. Asx/outlander mirrors are different (well my 2020 ASX mirrors are different) to my 2010 Evo X
I have already enabled it in ETACS, i am going to need to change my current ETACS unit for one post 2012 and the mirror switch i can source easily, just wondering if i would be able to Frankenstein it and use the CF mirror base but swap the entire mirror housing from an outlander of ASX including the motor onto it if the screw holes lined up.
Users browsing this forum: nmt and 14 guests
